Phone problems
12-02-2018 01:42 AM - edited 01-05-2022 06:13 AM
I made a payment of 54 dollars and got a txt saying payment was successful but then a hour later everything on my phone no longer worked why ?
Payment
12-02-2018 11:41 AM
Thank you so much! Works great I truly appreciate it!
12-02-2018 11:21 AM
@msheppard wrote:Don’t know if anybody can help me. I just renewed my plan for province wide calling. However it seems my region must be set differently as I can’t call out and it says I need long distance add on even though I’m making a local call. Help please!
Try the lost/stolen feature.
Log in to self-serve. Plan & Add-Ons from top menu. Lost/Stolen Phone from next menu. Suspend Service button. Log out. Wait a few minutes. Log back in and back to Lost/Stolen Phone and Resume Service this time. Log out. Restart phone.
See what happens.
12-02-2018 11:20 AM
12-02-2018 01:51 AM
@Courville89 wrote:Yes for maybe hour max
Sounds dumb but maybe it got flipped into airplane mode. Or the cellular radio was turned off.
What kind of phone is it?
12-02-2018 01:49 AM
12-02-2018 01:49 AM - edited 12-02-2018 01:50 AM
Thanks for the screen shot, looks like everything should be good to go
Restart your phone
If that doesn't work try this
12-02-2018 01:48 AM - edited 12-02-2018 01:49 AM
@Courville89 wrote:I made a payment of 54 dollars and got a txt saying payment was successful but then a hour later everything on my phone no longer worked why ?
Did it work after you made the payment?
See what happens.
12-02-2018 01:48 AM
12-02-2018 01:43 AM - edited 12-02-2018 01:45 AM
@Courville89What does your account status say? Is the payment still in your available funds or was it used to renew you plan? Did you make a payment after the cut-off date?
Can you send a screen shot of this?
