11-05-2016 04:25 AM - edited 01-04-2022 06:04 PM
Hello,
It seems the port is complete, and I can make a voice call. I cannot access the website.
Can you share some points?
Thanks,
Service
11-05-2016 12:14 PM - edited 11-05-2016 12:18 PM
@pssst You cannot install iOS 10 on the 4s; 9 is the last supported version. I'm pretty sure you can edit APN settings manually on the 4s running iOS 8 whereas folks on iOS 7 cannot.
Here is Apple's troubleshooting guide for this issue: iPhone data
11-05-2016 11:14 AM
@pssst check out the solution on this thread.
It might help othersout with other iphone models as well, not sure
11-05-2016 10:35 AM
I'm worried that if I update my IOs to the latest it will make my phone obsolete. I'm on iPhone 4s.
11-05-2016 09:15 AM
updated the package of iphone, and can set APN.
Not sure why it worked now
11-05-2016 08:54 AM
My ios is 8.4.
I have switched from Telus to Rogers, and did not change anything. Do not know why I need to change so many manually.
I can only set APN.
Can you share some links here?
11-05-2016 08:00 AM
I am having the exact same issue. It is showing that I have used data on my account but it is still showing that the network is not available on my phone.
11-05-2016 06:33 AM
Not an iphone users but from what i recall the most common issues are:
Do you have the latest software installed 10.1 installed?
have you put in the proper apn settings?
Iphone users mention something about profiles or resetting profiles.
some people have mentioned a website that will set up apn for you.
there is a guide for iphone on the forum somewhere, best to search the forums for apn and iphone
