06-01-2025 12:00 AM
Today it appeared that I am unable to connect to cellular service. I have the letter 'E' in one top corner of my phone and 'EXT' in the other corner. What does this mean?
06-01-2025 12:12 AM
That did the trick! Thank you 🙂
06-01-2025 12:03 AM
yes, look like there is a problem with your phone connecting to the network
Start with Rebooting your phone first, and try Reset network settings
and check the Telus outage map to see if your area have any reported outage
https://www.telus.com/en/bc/outages
as far as i can tell, Salmon Arm in BC has some mobile service issue
