05-31-2025
08:20 PM
06-01-2025
12:40 AM
computergeek541
Bell says my number was transferred to Public Mobile but I still don't have service
06-01-2025 12:39 AM
@hTideGnow wrote:Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
There could be a porting issue, but the porting team call centre cannot help and should not be contacted at this time. Having no service at all with Public Mobile isn't a porting issue. That needs to be corrected first.
05-31-2025 09:30 PM
05-31-2025 09:01 PM - edited 05-31-2025 09:02 PM
@Piper2025 wrote:I have a Bell SIM card
In your phone? You need to place your Public Mobile SIM card in your phone and reboot the phone. And if that doesn't work, the first response has another option.
05-31-2025 08:44 PM
05-31-2025 08:39 PM
@Piper2025 wrote:Thanks but I tried all of your suggestions and also just submitted a ticket. Is there anything else to do? I got an message from Public Mobile that the number was transferred over earlier today but still no service!
Did you get a SIM card or eSIM? And as silly as this sounds as it has happened time and time again, are you sure the Public Mobile SIM card is in the phone? Also, do you have another phone you can try it in?
05-31-2025 08:36 PM
05-31-2025 08:22 PM - edited 05-31-2025 08:22 PM
@Piper2025 wrote:Bell says my number was transferred to Public Mobile but I still don't have service
Hey @Piper2025
Have you tried rebooting your phone? Another thing is since you were with Bell, go into your Settings, find Network Settings and reset them. Then reboot.
If you're still not connecting, reach out to a CS Agent this way.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
