no 6 diget security text
LRu
Hi, I am not getting the 6 didget security code, and I don't seem to be able to select the email option, unless I am not looking in the right spot??
2 REPLIES 2
funpig1
Go into the login page. Type in your email. Type in your password. It should then send a six-digit code by text to your phone. If you do not receive it, you can look for  Send another code and at that point it should give you the option to send it via text or to your email. Good luck!
