newby
08-25-2019 05:24 PM - edited 01-05-2022 06:38 AM
I am new and do not have a cell so I am looking for a compatable cell with at least a 5" screen and the best camera possible (12-13mp). thanks
Al
Joining Public
08-26-2019 11:32 AM
@AFC, what do you want/need your phone to do? There are so many options.
Do you have experience with any of the operating systems? Do you prefer one over the others?
Personally, I prefer the operating to be basic and simple to use, and I don't want the fluff installed on it that doesn't work the way I expect it too. I find Android-based devices to be my preference, although I have non-cellular mobile devices with iOS.
08-25-2019 08:25 PM - edited 08-25-2019 08:26 PM
It depends on your price range. You can get unlocked Android phones at Staples for around $200 like Acer and refurbished Motorola G Play.
It you are willing to spend more. Pixel 3a has a very good camera and you get the latest software updates from Google.
08-25-2019 07:02 PM
08-25-2019 06:35 PM
Check on sites like Best Buy...you can get a refurbished Iphone or something similar for $150 or less. I guess it depends on personal preference but IMO...they want wayyy too much $$ for new phones of most any brand. Whatever works best for you and your budget.
Welcome to Public Mobile ...if you take that step.
08-25-2019 06:07 PM
@AFC wrote:I am new and do not have a cell so I am looking for a compatable cell with at least a 5" screen and the best camera possible (12-13mp). thanks
Al
It's hard for people to give advice without knowing how much you will spend and which operating system you want.
08-25-2019 05:26 PM - edited 08-25-2019 05:28 PM
Umidigi a5 pro
I'll get that one once I need to change
I heard a rumour that you can get it for 120 brand new if you shop around. If you shop fast Amazon has it for 170
