03-22-2024 10:28 AM
I'm not sure if my phone number was transferred properly to Public from my previous carrier. I need to know whether it was done and was successful or if I need to contact the previous company and go through th e steps again.
03-22-2024 10:51 AM - edited 03-22-2024 11:00 AM
@CKC - Hey, then that is a porting problem, I will send you the number for the team in the private message: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
If you get any email from Public Mobile or your old provider about a port issue then use the number I sent you there.
03-22-2024 10:50 AM
so far everything seems to work except direct texts to my phone number. However, texts mac to mac work.
03-22-2024 10:46 AM
And, got an email a few minutes ago from the previous company...
03-22-2024 10:45 AM
Well, dang. I thought I did right but I guess i didn't. I received 2 messages - one to say yes to and I did. Then another much later that to say no to PM. Okay, I just called out and 2 people called in and it works. Testing out to see if I can get a text but it hasn't shown up yet.
03-22-2024 10:44 AM
@CKC - Try your old SIM card from your old provider, if it doesn't work, then the port is complete.
If you don't have your old SIM card from your old provider, try logging into your account.
03-22-2024 10:35 AM
@CKC wrote:Hi - I did do that and it seems to be working but the other company says it hasn't ported.
If your new PM service is working as expected...I reckon you're good to go. Welcome to PM.
03-22-2024 10:32 AM
It takes a few hours for port to be completed. Did you respond YES to the old carrier's port request.
With your PM SIM card in your phone, are you able to receive phone calls and texts at your phone number? If you are able to recieve calls and texts, your port is likely successful.
Or you can try your old carrier's SIM card in your phone. If it is working, then your port was not successful.
03-22-2024 10:32 AM
03-22-2024 10:31 AM
so did you receive the port request text to which you needed to reply YES within 90 mins ? If you did...try the PM sim in your phone to see if ALL features work as expected.
