new activation
Morris1
i  purchased a new phone and activated a new account on April 19th, 2023
Public mobile has verified that i have been accepted.
i can send and receive texts.
i can phone out but incoming calls still go to my old Virgin phone
i called  Virgin Mobile, yesterday, they told me that they have not been contacted by Public Mobile to request the transfer of my phone number to public mobile.
It has been 4 days now,
can anyone help me.
Yummy
HOW did you request number transfer?
Did you follow process to the letter? - both account active, keep OLD SIM in a phone, initiate porting, reply Yes within 90 min of receiving SMS from other provider?
maximum_gato
@Morris1
Did you reply YES to the PAT (porting authorization text) within 90 minutes of receiving it? Or recieve it at all? When you call the telus/koodo porting department make sure you have your virgin account # to give them to reinitiate your port request and put your virgin Sim card back in your phone so you can reply YES to the PAT.
pmva
@Morris1 There is a number to contact the dept that ports numbers and they may be able to assist.  I will DM you the number, so check you community inbox.
