New Sim Card
CallaFarn
So, I changed my sim card, updated the new number in my account, got an email confirming that my new sim card number has been activated, but when I try to use my phone, it says "not registered on network". I tried turning  my phone off and on again, taking the sim card out and putting it back, etc. Nothing
12 REPLIES 12
maximum_gato
@CallaFarn
Sorry about that....often only the main Sim IMEI# will be blacklisted in a dual sim phone. Good Luck hopefully you had an honorable seller.
CallaFarn
Rats!! The emei number is blacklisted. But not the emei E sim number. I will contact the seller, but not too hopeful.Thanks very much. This appears to be the issue. Thanks, all.
maximum_gato
@CallaFarn
Check your IMEI# at device check to rule that out.
CallaFarn
Checked. SIM number matches.
CallaFarn
New to me. Second hand. Samsung Galaxy S22 Ultra.
@CallaFarn
did you make the sim card change request using a Desktop or phone?  there is problem requesting sim card change if you use a phone
If you used a desktop or laptop, it is good, try to reboot the phone once again
Also, go back to to My Account using Incognito mode, check the profile page and see if it shows the new sim number.  If it does, then you need PM support to help to re-provision the sim card
maximum_gato
@CallaFarn
A new phone....new, new or second hand new?
Edit:
If it's the latter perhaps rule out blacklisting first....
https://www.devicecheck.ca/check-status-device-canada/
Have tried the new Sim card in another device? Do you have one you can borrow to see if the Sim card gets the same message?
CallaFarn
Lost my last phone with the SIM card, so bought a new phone and card.
CallaFarn
Lost my last phone with the SIM card. Bought a new phone and card.
Dunkman
@CallaFarn
You might also want to double check your self service account to make sure that the SIM card numbers match. Make sure that there were no typos when you entered the new SIM card number.
maximum_gato
@CallaFarn
It's quite possible that when you changed your Sim card it didn't provision correctly to your account. Do you have your old Sim card? Was it working before you swapped Sim cards? If yes put it back in your phone and see if it works. If no then you just transferred your issue to your new Sim card and will need to contact customer support to fix it.
Click on SIMon at the bottom of your page to submit a ticket or send a private message using the link below if you cannot use the chatbot.
popping
@CallaFarn
You are doing the correct procedures to your phone working after switching to a new SIM card.
What is your reason why you want a new SIM on your account?
