03-19-2019 11:35 AM - edited 01-05-2022 03:48 AM
I joined public mobile yesterday but I have not had access to my phone yet, it notes network unavailable. Do I have to configure something? By inserting the SIM card, it says that the IPhone is not activated, but it is.
03-28-2019 05:20 PM
@paulomontedo24 wrote:Thanks, after 15 days, at the moment the internet is working ...
That is good news. Did you do anything or did it just start working?
03-28-2019 04:55 PM
GOOD NEWS!!! Never give up!
03-28-2019 04:49 PM
03-28-2019 12:06 PM
@Lieux wrote:@Anonymous la prochaine fois en français??!!
Just tryna help the guy. He posted a while ago in portuguese. The moderators were apparently no help for him.
Além disso, verifique willmyphonework.net para se certificar de que seu telefone é compatível.
Also check willmyphonework.net to make sure your phone is compatible.
03-28-2019 12:00 PM
@Anonymous la prochaine fois en français??!!![]()
03-28-2019 11:56 AM - edited 03-28-2019 11:56 AM
@paulomontedo24 wrote:I made a plan on March 13, 2019 and until that date I do not have internet or voice service, I've been through more than one moderator and blinker have the greatest goodwill I'm in the same, I advise to change company because this public mobile leaves a lot to be desired ....
Google Translate:
Encontre o seu telefone na lista a seguir para definir as configurações.
Find your phone on this list:
Officially Recognized APN Reference
Se o seu telefone não estiver lá, talvez isso funcione.
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Experimente também o recurso perdido / roubado no autoatendimento, suspendendo seu serviço e, em seguida, faça o logout, depois retome o serviço e reinicie o telefone.
Also try the lost/stolen feature in the self-serve by suspending your service then log out then resume service then restart phone.
03-28-2019 11:46 AM
Oh..sorry for all trouble...
If you want some people can help you here..or say that they can't but they will try! Post a new thread here and give details of what happened and what did you try...https://productioncommunity.publicmobile.ca/t5/forums/postpage/board-id/getting_started ...good luck.
03-28-2019 11:43 AM
03-26-2019 02:52 PM
@Gaetan_L Wrote: "
Hi,
I think this will require the help of a moderator @Moderator_Team !
After talking with @Sonia2 her phone gives the following recorded message when someone calls:
5UM3 Number has not been set up to receive calls
Please provide assistance quickly, it's been a week without full service!"
I think may be someone block @Sonia2's phone number. That's way got this message:"5UM3 Number has not been set up to receive calls".
03-26-2019 02:28 PM
Hi,
I think this will require the help of a moderator @CS_Agent !
03-19-2019 12:37 PM
If you have number ported from another carrier,
check if you have recived this message from public mobile saying that your transfer request has been completed successfully. otherwise wait because your porting is not successful.
if it is new number, check on websitefor your plan details stating which plan is active and when it was activated which will give you idea if the account is setup perfectly or not.
try checking simtray, properly inserted, also your phone has to be unlocked.
03-19-2019 11:54 AM
First, make sure your iPone is unlocked. Second, make sure you have activated your sim card on https://activate.publicmobile.ca/
03-19-2019 11:46 AM
@Sonia2 wrote:I joined public mobile yesterday but I have not had access to my phone yet, it notes network unavailable. Do I have to configure something? By inserting the SIM card, it says that the IPhone is not activated, but it is.
Some areas in Canada are experiencing service disruption today. If you're in or near Quebec, you could be affected by that disruption.
03-19-2019 11:46 AM - edited 03-19-2019 11:49 AM
If old carrier SIM no longer works, and your new PM SIM doesn't provide all your plan features, then your PM plan needs to be re-provisioned.
Try the lost/stolen phone trick:
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Reboot phone.
However, if your old SIM card still works, keep using until the service stops, then insert Public Mobile SIM
EDIT: Sonia, you activated your PM SIM card, correct? And your iPhone is unlocked?
