04-02-2022 11:40 PM
just activate my new sim and a new account. the sim is not connecting to the network shows emergency only.
I got another sim and change the sim on the website. the result is still the same. both sim cards aren't connecting to the network.
I tried to suspend the service on the website and wait 10 mins. it is still not working.
04-03-2022 12:35 AM
Send customer support a follow up message indicating your SIM card did not provision correctly upon activation. Pre-verify your account so that they can provision your SIM card to your account in the morning when they open for business at 6am eastern. This way customer support will have hopefully already provisioned your SIM card before you wake up to check your private messages.
04-03-2022 12:09 AM
I have tried 3 phones with 2 different sim cards and no luck. I just sent them a PM.
04-02-2022 11:49 PM
@wendigo do you have another phone to test ? Just want to confirm it is not a device issue
Of course, since you just activate, it could be just a SIM provisioning issue
I suggest you to first try your sim on another phone first if you have one around. If that doesn't work or you don't have a 2nd phone, open a ticket with PM Support and have them to confirm the SIM provisioning. to open ticket with PM Support:
1. If you have access to Self-Serve My account: For faster response (2-48 hours) , Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. If you don't have access to My Account or have trouble with above method: you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
04-02-2022 11:49 PM
@wendigo wrote:just activate my new sim and a new account. the sim is not connecting to the network shows emergency only.
What's yuour phone model? There's a chance that the device isn't compatible. There's also the possibility that a activation system error didn't set up your service properly.
04-02-2022 11:49 PM
I take it you are not porting a number over, you are taking a new number from PM?
