04-03-2022 12:43 AM
04-03-2022 02:53 AM
In that case you will definitely have to go the CSA route. They should be able to get you back on track
04-03-2022 02:53 AM
@janetordonia wrote:My password and security question is not working when I am resetting. I forgot both
Please use the instructions that I provided earlier. You won't be asked for either of those during the ticketing process. The procedure that I've mentioned to you isn't the automatic password reset page. It's a form to ask a customer support agent for help.
04-03-2022 02:35 AM
04-03-2022 12:47 AM
@janetordonia wrote:Hi there,
my account was locked. I forgot my security question.
Go to https://widget.telus.tiia.ai/publicmobile/publicmobile.html and type "forgot security question answer".
04-03-2022 12:46 AM
You can wait 1 hour and try again when it becomes unlocked or you can contact a CSA by choosing the chatbot in the lower right hand corner.
