03-10-2022 06:34 PM - last edited on 03-10-2022 10:15 PM by computergeek541
I have activated my SIM card.
I have chosen a new phone number
the phone is not connecting to public mobile
03-11-2022 06:20 AM
@Maclynne - what happens when you try to call the number you choose?
Delay in activation requiring a bit of more time is not supposed to happen, but it has before.
Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
If issues persist after others suggestions ask CSA to check on your account.
Two methods to reach them here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
03-11-2022 04:02 AM
Phone is not locked, is it possible to try the SIM in another phone or another SIM in this phone.
Just to narrow the problem down.
New phone as well? brand new or used?
03-11-2022 02:35 AM
My nephews did the same thing, you have to go into the setting about phone, etc and set the information for public mobile service... I'm using android so it automatically setup the phone when I put my sim in, but my nephew is running iPhone and I had to set it up manually.
03-10-2022 08:08 PM
Try:
If none of this works, try the PM SIM card in another compatible device to see if you have full services, this will help establish whether SIM/account issue or device issue.
03-10-2022 06:44 PM
And I guess you picked a plan and paid for it?
What your self-serving account says? Active?
Rebooting might help. Removing and putting back SIM might help too. Maybe contacts are loose or dirty?
03-10-2022 06:36 PM - edited 03-10-2022 06:37 PM
@Maclynne, Did you restart your phone? If it is the first PM account for this phone, are you sure the phone is compatible with the PM/Telus network? Is there an error message, or something similar on your phone?
