06-19-2024 01:53 PM - edited 06-19-2024 01:56 PM
06-19-2024 01:56 PM - edited 06-19-2024 01:58 PM
@Peterjstock you will lose that balance , just pick the option to change plan on renewal that way you won’t loose money and in 90 day are up . You will be switched to the new plan you choose . Changing it immediately and you will loose out on your current cycle . There is no pro rating with PM
Add pic for illustration
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
