need agent to process porting transfer cs_agent
dxfinlayson
Public Mobile needs to send a request to Bell to port in my cell number. I requested earlier today, but there was a problem with an earlier request on Wednesday with a different carrier.  I have resolved that but they said Public Mobile needs to request again and it will go through. Also - I do not want to install an eSim . I bought a Public Mobile sim card which I would like to activate.
7 REPLIES 7
@parasol  If this is about your US add on problem then the phone number will not help as they only deal with number transfer problems.  You would need to contact customer service via private message as suggested to you in the other thread/s.
@parasol
number sent, please check your community inbox
@parasol  Sent !
parasol
can you send me their number please
@dxfinlayson  I sent you the porting team number they can help quicker . But here’s the link for CS Agents
send  a  private message   To CS_Agents
dxfinlayson
need customer service agent
cs_agent
@dxfinlayson  I’ll send you the porting team number private message . Give them a call they can re trigger the port request for you
