Friday
I'm logged in to my Account and I cannot find the details of my subscription plan. Where can I find this info?
Friday - last edited Friday
@charisliving wrote:Thanks for this, Mayor. What I’m really trying to find out is whether my plan has unlimited Canada‑wide minutes and messaging, along with unlimited international texting. None of that is mentioned in the 'Subscription & Addon," page, which makes things difficult. Cheers.
All current plans offer unlimited Canada wide minutes and international messaging. If you're in sunny Manitoba, you must have a cell that is VoLTE enabled and on Public Mobile whitelist.
clipped from Learn More...
What's included
Friday
Friday
using the Public Mobile app ?...log in to your account and on the landing page you should see Usage Breakdown...all plan details and add-ons should be easily identifiable there.
Friday
do you see anything after you login?
if you are using browser to login My Account, click Subscription & addon on the side pane and you will see your current plan
