10-26-2019 12:35 AM - edited 01-05-2022 07:44 AM
I purchased a second number, and that number doesn't work in my phone. My first number is also with public. There's no issue, but the second SIM card shows no service. I've already activated a plan for it and paid. Pls advise. Thanks!
10-26-2019 02:24 AM
To submit a ticket to Public Mobile do the following:
10-26-2019 02:21 AM
@sidongfu Power down your device remove the problem sim for 15 minutes. Reinsert the sim and power up your device. Does your sim work?
If not, you account needs to be reset by a PM moderator do you need to submit a ticket to PM.
10-26-2019 12:40 AM
@sidongfu , did you confirm that your second account is active? Check also the SIM card number registered in the account to make sure it matches. If you convenient check using a different phone to rule out phone problems. If this troubleshooting doesn't identify any problems, I suggest contacting the moderator team for assistance. The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. Refer to the following knowledge base article for additional information on the moderator team.
10-26-2019 12:38 AM
@sidongfuSwap your new SIM card into a known working phone to figure out if it is an issue with your phone or SIM card. If it has been narrowed down to the SIM card you will need to contact the moderators by clicking on the ? on the lower right hand corner.. expect to hear from them in 2 days.
