09-29-2021 07:25 PM - edited 01-06-2022 03:39 AM
My account is on autopay and it didn't automatically top up today and says I need to reactivate my expired plan so I tried and it keeps saying my account already has enough funds and wont allow me to add on
I can only make a phone call while in wifi but nothing else is working
Wondering how or what I can do to restore my phone as I need it for work
09-30-2021 11:50 AM
Thank you it worked doing this
09-29-2021 10:14 PM
Follow this method when making a manual payment/adding a card to the account....only use the emboldened portion of the instructions if the payment card is already on file.
Once you successfully update your card do not attempt your payment immediately. Log out/in then go to make a payment to pay for your renewal. Otherwise if you were not suspended I would recommend a $1 test payment. Follow my further instructions for a successful payment to unsuspend your account.
Do not try more than two attempts at adding a card or payments ( successful or not) or you will continue to get this message. Wait at least 1 hour to try a third time another hour for your 5th try....and so on....and do not make more than 4 unsuccessful tries with the same card in a 24 hour period or you will trigger a fraud alert lock out requiring assistance from customer support.
Go to make a payment. Choose the "other amount" option and add $1 more than the amount owing and submit the payment. If that is successful go back to your overview page and if it does not say active click on the reactivate button. If that works log out and reboot. If that does not work and your payment is in your balance rather than showing $1 then go to the usage or plans page. Click on lost/stolen and suspend your service. Log out/in. Resume your service. Your balance should now be $1. Log out and reboot.
09-29-2021 09:49 PM - edited 09-29-2021 09:50 PM
@Norman76 wrote:My account is on autopay and it didn't automatically top up today and says I need to reactivate my expired plan so I tried and it keeps saying my account already has enough funds and wont allow me to add on
Log in with incognito mode.
If you have enough funds in the account, try to Suspend then Resume service.
If no Available funds, try making a payment again.
09-29-2021 09:08 PM
Noticing your subject line of “Monthly Plan”… you do know there are no monthly plans here, right? 30 days, not a month unless you happen to have one of the grandfathered 90 day plans. Just in case this causes a late to top up problem for you.
AE_Collector
09-29-2021 07:31 PM
@Norman76 Have you tried reactivating using incognito/private browsing mode? What's your renewal date?
09-29-2021 07:30 PM
@Norman76 : If your payment card is still valid then make a manual payment and choose "Other" instead of Amount Due. Get your balance up to at least your plan cost and it should renew.
09-29-2021 07:30 PM
After you manually add the funds, does the added balance display in your Available Balance line?
If the amount there equals or exceeds your plan amount, try tapping the "reactivate" button.
Then logout of the online system. Reboot your phone. Try using it again.
