02-02-2026 11:41 AM
I am currently on a monthly 18$ / month but with only 250k data, there is a new 18$ plan with 1G data at 4G, is that correct?
02-02-2026 11:51 AM
yes, the new $18 plan has unlimited calling with 1GB, but you have to actually change to that new $18 plan
if yours was just $15 plan and just got a $3 hike and you didn't explicitly make a plan change, then you still have the "old" $18 plan
02-02-2026 11:50 AM
The new 18$ monthly plan has unlimited talk time in Canada, correct?
02-02-2026 11:44 AM - edited 02-02-2026 11:45 AM
@Samhorns Yes if you see that plan still available to you in your account just make sure you make the change for. Next renewal and not immediately so you don’t lose $ . I made that very switch monthes ago when they took away our $15 plans
02-02-2026 11:43 AM
hi @Samhorns
not sure if it is still available. But please login My Account, click Change Subscription page on the top right and check if you see the plan
if it is there, use Change on Renewal option to schedule the plan change
