mobile network not available
xiaoyiwang2018
my phone stop working today and I can't make any outgoing calls or receive incoming calls. when I made the call, "mobile network not available" is shown on the screen.  I have google pixel phone.
my daughter also has pixel phone on public mobile. so I switched her SIM card to my phone and it works, and my SIM card does not on her phone.
I checked my account status and it is Active, without any issue.
looks like a SIM card issue? Any suggestion?
Thanks
11 REPLIES 11
xiaoyiwang2018
Only my phone. Others are all good and all on public mobile network. Thanks
darlicious
@Oval
Exactly the same or similar? Everyone in your family? Have you checked for a network issue in your area?
xiaoyiwang2018
thanks and just sent out a request.
Hi @xiaoyiwang2018 sim card rarely have problem, I think it is account problem.  Please open ticket with CS agent for them to check
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
xiaoyiwang2018
hi, I tried 611 and I am getting the same error "mobile network not available". thanks
xiaoyiwang2018
hi I live in Markham. thanks
xiaoyiwang2018
everything does not work 😞
Oval
Are you in Renfrew County?  My family is having the same issue.
darlicious
@xiaoyiwang2018
Is it only your calling features affected or all of your services? Texts? Data?
@xiaoyiwang2018 since you checked your sim card on another phone and still cannot connect, look like Sim or account issue.  Please open ticket with PM support and have them confirm
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
HALIMACS
Try your sim card in her device and see if it works?  (Edit: excellent, you've already done the preceeding 😉)
Also what do you hear when you dial 611 with your sim card in a device?
It will tell you the status of the account that way. What you're viewing on the self-serve page may be outdated and cached information.
