mobile data not working
RickyDee100
I am in Hawaii. Voice and SMS roaming work, but mobile data does not . I am using an iPhone XR with a Public Mobile eSIM. iOS does not show Cellular Data Options, Data Roaming, or Network Selection. I've been advised i need to tell Public Mobile to refresh my U.S. roaming data.  But i seem to have no way of requesting this as a fix.  Anyone know of a solution?
7 REPLIES 7
RickyDee100
when i'm in the cellular data page, i have (top to bottom) List, Primary (with my ph. number) and blue checkmark to the right of it, and below that (greyed out ie non clickable) inactive physical.  This is an old physical sim which i'm no longer using but left in the phone.  The in another field below, also greyed out is 'Allow Cellular Data Switching' and an inoperable toggle to the right of it
hi @RickyDee100
try this:
Settings, then  Cellular (or Mobile Data) , and on the next screen  tap on the number you want to turn on data roaming
if you don't see it, can you screenshot and post here?
RickyDee100
where will i find a roaming toggle on iphone xr.  i don't see it anywhere in settings
hi @RickyDee100
enable mobile roaming on an iPhone, go to Settings, then  Cellular (or Mobile Data) , and  Cellular Data Options, then turn on the Data Roaming switch
next, change the network carrier, Settings , then  Cellular/Mobile Data then,  Network Selection, turn off the "Automatic" toggle and  wait for networks to load.  You should see AT&T, T-Mobile and Verizon.  Click on each one and try
RickyDee100
when i follow this path when i get to cellular data, it is on my 'primary' my number with a blue check.  no other options
Chalupa_Batman
Hello @RickyDee100
I have the XR as well. When I went to the US last, I went into Settings, Cellular, I turned on Cellular Data, then clicked on Network Selection and turned off Automatic. Waited for AT&T and T-Mobile to show up, picked T-Mobile, then scrolled down to Data Roaming and turned it on. I rebooted the phone and I was up and running.
hairbag1
@RickyDee100
try a network reset then make sure Roaming is enabled. If you need to get Customer Support involved, click the orange chat bubble on lower right side of the page to start the process.
adding...if that fail, use this link to dm Customer Support with your request...
