06-03-2022
08:34 PM
06-03-2022
11:01 PM
computergeek541
How can I check remaining minutes on my iPhone 7? I don't want to have to go to the website to do this. Is there an application that allows me to do it?
My Account
06-04-2022 09:57 AM
Thanks for that reminder.
djr
06-04-2022 09:56 AM
This is a fine workaround, one unknown to me, so I'll follow your instructions. Thank you.
djr
06-03-2022 09:35 PM
Get over it......log in and check.
06-03-2022 08:55 PM
Your usage is up to date on your account.
The phone tracking is not reliable and PM plans is a 30 days cycle not monthly.
06-03-2022 08:47 PM
@leathersmithe...if you do have the $15 plan with limited calling...consider getting the $5 / 500 minutes of Canada wide calling add-on. They'll get used if you run outta regular plan minutes. If you have unused add-on minutes at renewal..they'll roll over until you use 'em up...even if that takes several month or more.
06-03-2022 08:38 PM - edited 06-03-2022 08:39 PM
@leathersmithe So, no app can track minute used on the phone. There are apps for data tracking but not voice minutes
You have to use My Account to track. To make access a bit quicker, you can make a shortcut on the Homescreen and just click on it to launch the site, which looks like an app 🙂
Details steps here: https://www.macrumors.com/how-to/add-a-web-link-to-home-screen-iphone-ipad/
06-03-2022 08:38 PM
@leathersmithe - if you are on a limited minutes calling plan the only way to see what is remaining is on your self serve account under your overview section.
https://selfserve.publicmobile.ca/Overview/
06-03-2022 08:37 PM
If you have the $15 plan you start out with 100 minutes of outgoing calls from Canada to Canada. Log in to your account My Data and add-on and you should see how many minutes out of 100 that you've used already.
