03-16-2020 07:27 PM - edited 01-05-2022 09:57 AM
03-17-2020 07:30 AM
@Pierreroy1944 Turn airplane mode on. Wait 5 min. Turn airplane mode off. Try sending/receiving text messages.
03-16-2020 11:37 PM - edited 03-16-2020 11:40 PM
@gblackma wrote:@Pierreroy1944 how long ago did you port your number? A cell number can take up to 3 hours and a landline 2.5 days to complete.
Porting has no no relation to the inability to send outgoing text messages. Even if a port has failed, outgoing text messaging would still work.
03-16-2020 08:13 PM
@Pierreroy1944 If you have an iPhone make sure SMS and MMS are turned on.
03-16-2020 07:35 PM
03-16-2020 07:31 PM
@Pierreroy1944 how long ago did you port your number? A cell number can take up to 3 hours and a landline 2.5 days to complete. If Its been longer than that, your port may be stuck. Contact a moderator. Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon. Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket). If you do not have an account, contact them directly using this link https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
03-16-2020 07:31 PM - edited 03-16-2020 07:31 PM
More details please.
What kind of phone do you have?
Did you just port your number from another provider?
If yes, how long ago?
What works and what does not?
Calls in out?
Text in and out?
Data?
What plan are you on?
When you say you can't send a text..are you talking about a normal sms or are you by chance talking about a MMS picture text?
