lost my sim
11-07-2024 02:10 PM
I lost my sim and i want to stop my payment. system is sending code on my sms that is cant not received.
Payment
11-07-2024 02:38 PM
@qamer Do you see option that says “didn’t get code” tap it and you should get option to send code to email instead .and once you have new sim card in hand go to to your profile page and sim swap the number like this
SIM SWAPPING profile tabs
Of course if you cannot log in you can contact support to help sim swap the number also
11-07-2024 02:14 PM - edited 11-07-2024 02:19 PM
hi @qamer
just message support here and they can help
but you sure you dint want to buy a new PM sim and use it in the replacement phone?
if you want to do that, buy a PM physical sim card form Telus or Koodo store or via Amazon:
Telus or Koodo store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
Then message support agent and ask them to help to update your account with the new sim card:
![](/skins/images/C206B3E09108DC4A8294A110EB9CCA46/responsive_peak/images/icon_anonymous_message.png)
