04-25-2022 03:32 PM
04-25-2022 03:40 PM
hi @ben1994 The critical part for self retting password is the answer to the security question. If you cannot answer than, then you will need to open ticket with PM CS Agent. At : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
04-25-2022 03:34 PM
@ben1994 You'll need to ask for a password reset by submitting a ticket via chatbot here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If unable to submit a ticket, then send a private message to CS_Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
