04-25-2022 01:43 PM - edited 04-25-2022 01:45 PM
Hello,
I received a text message from Public Mobile saying that my credit card will expire at the end of the month. My confusion is that my credit card will expire in April 2025. Was there a system glitch or am I required to update my account information in any such way?
Kindly guide.
04-25-2022 03:40 PM - edited 04-25-2022 03:41 PM
It is most likely a glitch that you got the text.
04-25-2022 03:05 PM
They have been known to send some texts either in error or jumping the gun a bit on dates etc.
If your card is showing up correctly in your account with the proper expiry date, you should be good.
04-25-2022 01:58 PM
Most likely PM somehow failed to process year correctly.
If you are really concerned and worry of renewal failure I would contact agent to double check why yo are getting this message. Then you will have in writing your card is OK.
Use the ticketing system for a faster response time (preferred method as Ticket is assigned and easy to follow up with CSA). Click Chatbot - Ticket and type ticket, then click on Contact Us, then click on issue you inquire about. Link for creating ticket will be presented.
- Send a private message to the CSA - agent by clicking Here
If you are concerned
04-25-2022 01:54 PM
Your current card is well into the future. Are you sure you didn't register the previous card here with a now looming expiry?
If only there was a way to see the current card details as registered. All we can see are some digits of the 16 digits. Unless maybe the number changed.
04-25-2022 01:46 PM
Yes, this happens for me too.
Same question.
