04-02-2023 07:14 AM
sim card is puk locked, where do i get the sim cards puk.
04-02-2023 09:38 AM - edited 04-02-2023 09:49 AM
@Leannefaye wrote:sim card is puk-locked
@Leannefaye you have been using sim card pin for protection and you need to enter the PIN every time the phone boots up?
If that is indeed a sim card PUK you are looking for, open a ticket with PM Support using this direct link: https://urlshortner.tiia.ai/Oyn1L6
04-02-2023 09:36 AM
04-02-2023 09:00 AM
What is the exact message showing on your phone?
There are various unlock codes.
When and where did you get your phone? Is your phone locked to previous carrier?
