05-20-2019 10:41 AM - edited 01-05-2022 05:00 AM
05-20-2019 11:11 AM
@JohnJohnston wrote:hi I been locked out into my two acounts how do you fix it?
Did you try the button FORGET MY PASSWORD?
If yes and nothing helped you need to reach the moderator here for help..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437. Waiting time is few hours to 2 days. Be patient. if you need to top up your account you can use the 611(with a credit card in your account) Or with voucher.
05-20-2019 10:49 AM - edited 05-20-2019 10:51 AM
You could try using a different browser or use incognito mode. Also you can reset your password.
Resetting your Self-Serve password
If you forget your password, there’s no need to worry. You can create a new one by following these simple steps:
