09-10-2022 08:51 AM - last edited on 09-11-2022 02:37 PM by Dunkman
My sim was brand new but she told me is invalid
09-10-2022 02:20 PM
That was already said more than 4 hours ago.
09-10-2022 09:47 AM
Where you got the sim card from ? you sure it was never been activated?
SIM cards are all one time use , can only be activated once
I would try again using Incognito mode, but I suspect you will get the same result. If that is the case, Please message PM Support for assistance
09-10-2022 09:06 AM
@malfesant12 - were you successfully charged?
Is your account status Active? Log into My Account or try calling 611 to check.
If Active try one or more of the below:
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
*try your SIM card into another compatible phone...this could rule out a device issue/setting.
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
If issues persist, submit a ticket to CSA to check on this new account activation.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
