I need tech support
MarketMama
I am at my trailer in Ipperwash Ontario. No signal for over a week!  Help.
2 REPLIES 2
@MarketMama  - is your account status Active? Log into My Account or try calling 611 to check.
If in suspended status, make a manual payment and reactivate.
If in Active status, try 1 or more of the below:
  • restart your phone
  • toggle into and out of airplane mode
  • perform a Reset of the device's Network Settings
  • move your sim card to another phone to see if services works
  • manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) to see if services work
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
If issues persist, submit a ticket to CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
