Number not assigned
Modah
Hi,
It says my number is not assigned. I recently transferred my number from Eastlink to public Mobile
7 REPLIES 7
Alexandf
@Modah
open ticket with PM support and ask them to check it your account.
 At https://publicmobile.ca/chatbot.
have trouble with Chatbot: Private message CS Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
@Modah - if you still have the Eastlink SIM card, insert it in your phone to see if the SMS text comes in.
Ensure you Eastlink account is still active for successfully porting.
You may also submit a ticket with Public Mobile representatives (CSA)to restart the porting process here (which you will need the Eastlink sim in your phone to complete)...for issues with transfer/porting of phone numbers over to Public Mobile.
@Modah   Please check the community inbox, will send you the Porting team support number
Modah
Hi, I can not receive calls
Modah
I believe the number hasn't been finished transferring for some reason. Could you please send me the request to transfer it again and I can send yes
@Modah  was it over a month since you requested transfer of the number?
or did you called Eastlink to cancel the account yourself?  It sounds like the porting wasn't completed and got into trouble
Login to My Acocunt, Check the Profile page, what phone number is it showing?
Outdoorsman
@Modah Hi are you receiving incoming calls was your transfer complete?
Did you get your transfer request to port your number? If not your port may have failed please let us know if this is the case
