09-10-2022 09:10 AM
I need to sign into my son's account to pay his bill, but forgot email address.
09-10-2022 02:26 PM
@Alexandf- The customer did not ask about changing the email. What are you reading into these posts that you reply with something that seems irrelevant?
09-10-2022
02:24 PM
09-10-2022
03:06 PM
computergeek541
you cannot change your Account email address yourself. You have to open ticket with PM support and ask them to change it for you
At https://publicmobile.ca/chatbot.
have trouble with Chatbot: Private message CS_Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
go to store buy it vouchers and call *611 added to your account
edited by comptuergeek541: information about how to contact a CSA was provided nearly 5 hours earlier
09-10-2022 09:35 AM
to reset or change your email
you need the help of a service rep
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
09-10-2022 09:34 AM
@jeremyklassen best is to try using the Forgot Password Link on the login page. You can try with all email addresses you have and see which one got the reset password email
If that doesn't help, then open ticket with PM Support and they can sort it out for you:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
