01-04-2024 06:40 PM - last edited on 01-05-2024 07:31 AM by computergeek541
Hello,
From august 2023, it's missing every month my 1 gig data from my account, which usually comes with my plan package .
What should I do?
who can fix these for me?
Thanks , Magdolna
01-04-2024 07:26 PM - edited 01-04-2024 07:27 PM
@Magdolna1 do all other services work can you call and text ? If possible take a screen shot off your overview page . Should show how much data you have and how much data you used . But if you not even seeing it there on your account please submit ticket with support using this direct link to investigate for you
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
01-04-2024 07:23 PM
I'm a 25$ plan and now for several month I do not have the 1024 MB data
when I try to use the internet outside home, it say to add-on data for $$
01-04-2024 07:19 PM
HI @Magdolna1
can you post the overview page of your My Account, even you used up the 1GB data, it should show there
but if the overview page not showing the 1Gb data at all, then this is something you need to ask agent to check. please submit a ticket with CS Agent here:
01-04-2024 07:18 PM
I have a :
30 day plan with
1034 mb at 3 g speed data,
30 day plaUnlimited Canada wide
Unlimited Canada wide talk
unlimited international text
all is was 25$ when I have started
01-04-2024 06:43 PM
You on the $25 plan @Magdolna1 when you log into your account dose it not show
Try again incognito/private mode
And or lap top /computer
OR
simply try refreshing the page to check data plan / mins / add ons
if it not displaying and you have no data please submit ticket
01-04-2024 06:42 PM
HI @Magdolna1
what plan do you have and how much data you are supposed to have?
check your My account's Subscription screen to confirm and check the overview page to see how much data assigned
if not match, please submit a ticket with CS Agent here and ask them to confirm
