10-20-2024 11:19 AM
Hi, I cannot activate my esim with eversafe because my phone is in SOS mode and cannot receive text. please advise
10-20-2024 11:54 AM
Then you will likely need to wait for customer service agent response. Another customer waiting about one hour for CSA to respond this morning. Hopefully, will get to you soon.
10-20-2024 11:49 AM
the public mobile sim remains in "activating" state
10-20-2024 11:48 AM
yes it's out, no physical sim in the phone, restarted several times, reset all network but still in SOS mode
10-20-2024 11:43 AM
@newbie1234 wrote:yes i have followed the QR code, got the app and activated the esim. my phone has another physical sim which is fine (now off) and i have restarted several times
Did you physically remove the other SIM card out of the phone?
10-20-2024 11:32 AM
this did not work
10-20-2024 11:28 AM
10-20-2024 11:28 AM
Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings
10-20-2024 11:27 AM
Was your phone in SOS mode before you activated your new account?
Might want to try a simple reboot of phone.
Did you recieve email with QR code with eSIM activation?
10-20-2024 11:26 AM
how do i reset all network on Iphone SE3
10-20-2024 11:24 AM
the eSIM is installed and set as Active? Did you try Reset All Networks?
if that still does not connect still, ask PM to check
10-20-2024 11:21 AM
@newbie1234 Support can re fresh your account in there end
