10-12-2022 09:49 AM - last edited on 10-12-2022 02:50 PM by computergeek541
10-12-2022 09:58 AM - edited 10-12-2022 09:58 AM
No change…are you on AutoPay?
There could be a glitch so login to your account and check if AutoPay is enabled.
10-12-2022 09:55 AM
Mine failed this month also and has been fine before as I have always been on autopay with the same credit card. From what I have read it just does that sometimes. I just went into my account and hit tge button that says reactivate. Not sure if it's a glitch but it seems to have fixed it for now.
10-12-2022 09:53 AM
Did your renewal fail?
There is no changes in CC usage so far
What kind of issues do you have? Little bit more info is needed.
10-12-2022 09:52 AM
@Anniesue wrote:why doesn't public mobile accept my credit card now when always did?
@Anniesue A few more details would be helpful so that people can narrow in on what the problem is. Did autopay fail? Is it renewal day and your account says "Suspended" (this is normal and if your service is still working ignore it.) Did your card expire? Are you adding a new one?
