Cellular data
BeachyBrandi
My husband and i have been having trouble with cellular data. I have an iphone and he has an andriod. Yesterday we both could not get on the internet or use any aps. And the same this is happening today.  Turned off and on airplane mode as well as the cellular data. Works for a few minutes and then cuts out.
Any ideas????
Thanks
142 REPLIES 142
humanoureen
my phone is constantly showing SOS or no service!!!!
HAVENSMommy
I did reboot phone, and it would work for a second and then out again, I rest the network settings and then another reboot and still no data.
HAVENSMommy
No I am in Ontario
Offalmangler
I am also having data issues in Markham area. Tried restarting my phone but found no change. Data worked ok this morning.
@duvey
could be but what area are you currently in ?
hi @duvey
possible there was some issues, mainly in Ontario and Manitoba
Try Reboot phone and Reset network settings
hi @JFitness
are you in Ontario or Manitoba? seems like PM has some data issue in the past 2 days.
Try reboot phone and click Reset network settings and test again
duvey
is data down
JFitness
  • I have been using PM for a year and a half with no issues, until now. Twice this month I have not been able to connect to mobile data unable to send or receive messages unless connected to wifi. I have an actual Sim card tried all the tricks. What is happening?
KrisMorrison
Hi all.
Thought I posted here, but dont see it.
I removed my SIM card (physical) while phone is on. Had to restart, and then worked for me.
If you have an eSIM could try turning off/disconnecting Public Moble one for 30 sec or so, (don't delete it) and then restart to see if that helps. eSIM worked for my wife.
gemini16
I'm in Alberta, I've not had Data for a while and all the settings settings suggested and the airplane mode and wifi assist turn off doesn't do squat. They need to get their act together and nake sure that the registered number is allowing Data on their network. I'm porting my number over to another provider. Tired of dealing with automated clowns and gremlins in their network. Fix the your Network!!!!!
gemini16
I have the same issue as posted. Doesn't work. Airplane Mode off, Wifi assist off. Get us help with this it's not the phone it's your crappy network that blocks Data access.
@Kelly58
This seems to be a problem for a few members for the last few days.
Contact a CS_Agent for a refund:
@Kelly58
you'll need to start by clicking the orange chat bubble on lower right side of the page to start the process  for Customer Support.
adding...if that doesn't work for you, use this link to dm Customer Support and request credit to your acct rather than refund.
Reboot phone and Reset network settings.  It will then resolve the problem
LexiLou29
No, in ontario
Kelly58
No data for 2 days! And I purchased extra for 15$ . I want a refund please
JONMILLS
Make sure you didnt turn on airplane mode
Ken19
tried it. it is still the same. so now either i use my data all the time or reboot my phone ever time i go out somewhere.
Raulsu
Seems like there is more widespread network problem happening. More threads here and in the public Mobile subreddit popping up about intermittent data loss.
MoodyJazz17
I noticed mine wasn't working all day yesterday either, same with my brother and we both have Public Mobile. I'm not sure if this was the solution, but this morning I just went into general management > reset network settings and restarted my phone and now it appears to be working for me
mneal
I should have added - Nothing I have done to troubleshoot has worked, reset phone, changed APN settings, toggled airplane mode, reset wireless network option - Seems like a Public Mobile problem - I rely on data and have not been able to use it for 2 days now.
KrisMorrison
Same in Cambridge Ontario. Support has been good with communication, but no details/fix as of yet.
Ask has been to check APN for Public Mobile.
mneal
I am in the same boat - Ontario.  Data is either intermittent, or not working at all - Seriously concerned with the service.
@Ken19
in your cellphone settings, disable Wifi Assist....see if that helps.
Raulsu
Same here, southern Ontario, been happening all morning. I'll have data and suddenly will lose it. Still strong network and can text and call. Only a phone reset or toggling airplane mode a few times fixes it.
Ken19
i restart my phone. then i have data but when i turn on my wifi the data turns off and won't reconnect . until i turn off wifi and restart my phone? any one have a reply. this is getting annoying. every time the phone connects to wifi.
@Tom2211
where are you located....seems there's some on-going issues in the province of Manitoba....you there ? How about talk and text...they ok ?
Tom2211
Obviously there is an issue with public mobile data services because multiple people have no data. I tried everything with restarting the phone, network, etc. Did anyone find a solution or answer to this issue?
@HAVENSMommy
log in to your acct using the app, look for Usage Breakdown to see current plan status. Can you confirm if talk / text are working still ?
