Data, SMS and voice
Moseline
Hi is been since last week I noticed that my network Is not working whereas I was still having data I don’t know why. I have noticed that with all this issue my account was debited. I need to know why.
1 REPLY 1
hi @Moseline
no service but you are still using data? are you using Wifi?
And voice calls do not work?
Try Reboot phone and click Reset network settings
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
