Sunday
Sunday
@Mario61 Try the forgot email option , if still no luck ask support to help
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
Sunday
your email shouldn't change unless you changed it in Eversafe.
If you get a new cell, you just remove sim from old cell and install in new cell. You should be good to go.
Sunday
hi @Mario61
you cannot even login or you just cannot receive 2FA?
if you cannot, ask PM agent to help.
you can submit ticket by direct message:
