an hour ago
- last edited
an hour ago
computergeek541
One more thing, during the activation, I missed the field to enter my wife’s referral code due to a page loading error.
Could you please manually add the referral code xxxxxxxxxx to my count? Thank you very much.
25m ago
@Adam413 wrote:I think I can get $10 credit if I successfully add the referral code.
Sadly, no.
If you read the fine print, section 16. I've super imposed the plan screen for you.
38m ago
45m ago
You can create a ticket this way via the bot. However, the bot is completely useless if you ask it " I forgot to add my referral code ". It doesn't not help you in any way. You will have to use " Create Ticket " to create one.
Just a side note, she will be only one that receives credit to her account. 1 point per month. You will not be receiving the $10 credit in your second month of service during this promotion.
58m ago
@Handy1 wrote:@Adam413 You will need to ask support to help apply it for you
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
Customers should be opening tickets through the chatbot.
an hour ago
