11-08-2016 10:28 AM - edited 01-04-2022 06:08 PM
anybody try to send a text message outside of canada. i did try to send the text back home however it does not work i can receive the international text but not send out anyboby have any clue what is wrong with it?
11-08-2016 03:04 PM
i have tried all diffrent kind of format it still won't work however i can receive the international text , even i just reply back in the same screen my friend just send me text oversea, it still won't work it is very weird
11-08-2016 10:33 AM
no problem with mine.
Maybe the format of the number?
Did you try using a different carrier and texted the same number with the same format?
Try to reply to the text you received since it's using the correct format.
