04-18-2015 02:56 AM - edited 01-04-2022 01:22 PM
04-19-2015 01:10 PM
04-19-2015 12:53 PM
@DK, you can also buy the second gen Moto E at TELUS for $150 as a prepaid package. If you're only planning on using it with Public it might worth saving the $29.
I think the phone holds up well against the first generation Moto G, it's a bit of a trade off though, the screen resolution is less but you get LTE access and SD card expansion.
04-19-2015 11:38 AM
04-18-2015 11:44 AM
From the "Plans" section of the Public Mobile website;
04-18-2015 04:27 AM
04-18-2015 03:24 AM
04-18-2015 03:23 AM
04-18-2015 03:04 AM
04-18-2015 03:00 AM
