11-13-2016 09:16 AM - edited 01-04-2022 06:17 PM
Looking to start in PM tomorrow when my sim arrives.
My question is does iMessage work fine on PM. iMessage activation goes through fine.
Thanks
Service
11-21-2016 09:53 AM
I actived a SIM for iPhone and ported my number from Wind, all working fine and no issues at all. With on my iPhone, I couldn't send/receive pictures from/to iMessage, but now with PM it resolves the issue. Here what I did...
- active SIM with new PM number
- ensure everything works on the PM number
- port Wind number to PM
- all happened and completed within 15 minutes.
11-13-2016 01:09 PM
11-13-2016 01:04 PM
All you need to do is take the old SIM out and put PM SIM back in. Your iPhone will do the rest 🙂
Are you going to port your no. over PM? if so, I hope it go smooth.
11-13-2016 09:45 AM
11-13-2016 09:44 AM
Yes I think that's the best way to port a number to avoid any issues. Get a new number and then port after you make sure everything works first. Imessage worked fine for me as well and all settings were automatic. One person did have difficulty with iMessage his past week but I pointed them to the below article and then hey were all set. Good luck and welcome to the community!
11-13-2016 09:38 AM
11-13-2016 09:35 AM - edited 11-13-2016 09:36 AM
@jgorman, activations are going through successfully for most people. Literally 100's to even thousands of new activations daily during this promo.
As for the APN settings on your iPhone, they are automatically set via a carrier update from PM. You should not have issues with this as confirmed by almost every PM customer on iPhone 5 and newer with the most recent iOS update running.
If you run into data connectivitiy issues, its almost always because there are multiple profiles on your phone from previous carriers. Simply removing old profiles helps in these scenarios.
11-13-2016 09:26 AM
I was one of the lucky ones, didn't have to touch any apn settings as soon as I put the sim in and my iOS was up to date, everything was fine!
11-13-2016 09:24 AM
11-13-2016 09:19 AM
Hello! @jgorman iMessage should operate the same as any other service, I have an iPhone and haven't had any issues.
