if i order a new sim card how can I leave the same number?
Kateryna
Recently I've lost my phone and going to order a new sim card. But i it possible to get a sim card with the same phone number I had for the lost phone?
@CS_Agent
1 REPLY 1
NDesai
Yes, you can. All you have to do is change the sim card number to new from your existing self-serve account. On the right side under your profile, you will find an option to Change Sim card number.
FYI, you can now purchase the sim card at your local walmart store.
