12-07-2018 02:44 PM - edited 01-05-2022 02:44 AM
I use an iPhone XS and I noticed that anytime I click on a number like +12895550505 I get audio saying that I do not have voice calling as part of my plan.
It is only when I click on numbers like this with ether + in front of it or and ext. at the end of the number.
Maybe its iOS. I never had this issue before.
Does anyone else have this issue?
12-07-2018 06:29 PM - edited 12-07-2018 06:37 PM
@mcs11 wrote:
@Luddite wrote:Think 011 is international long distance code?
Yes, 011 is the international long distance dialling code. I'm surprised that a phone would change from +1 to 011.
+1 is the way the phone displays the number. In North America 1 is all you need but if you have +1 with a North American number it will dial 001 which is exactly the same as dialing 1 when in North America. Outside you will need the 001(+1) to dial a North American number.
This is strange, I just checked my phone and all my outside NA numbers are displayed as 011.
EDIT: It seems to be quite random for my Canadian numbers, some have +1, some just 1 and some nothiing at all but area code, which are probably the ones that warns me long distance charges may apply.
12-07-2018 04:14 PM
12-07-2018 04:12 PM
I have an iPhone 8+ and before that an iPhone 5S. I have all my numbers stored with a + in front (Canadian or otherwise), just to facilitate long distance calling as I used to travel quite a bit. Like @Luddite, I haven't had any issues with connecting on these + numbers.
With extensions, these have never worked for me either. I have to enter the extension after connecting to the main number.
12-07-2018 02:59 PM
12-07-2018 02:54 PM
I noticed this myself a few weeks back. Couldn't complete the call.
However, when I double checked my call log, the outgoing number changed from +12895550505 to 0112895550505.
Try dialling without the +1, it should work.
12-07-2018 02:53 PM
Using an SE, and before that a 5. Have never had an issue with +1, but numbers with extensions tacked on never connect.
