Coverage under 3G plans
andmalc
Is coverage reduced when using a 3G plan?
2 REPLIES 2
Michael77
@andmalc,
Coverage should not be reduced.  You will just have slower data speeds.
xCameron94x
the 3G is actually throttled LTE (from what I've seen), so you will actually be connected to LTE, but the data speed will be close 3G speeds
