Account Problem AGAIN
dktam
Hi,
I am unable to log into my account and I've tried reseting the password, but for some reason it says my email/ username is incorrect. NEED HELP ASAP
Thanks,
CS_Agent
Customer Support Agent
Hi @dktam,
I just sent a private message to you, please read it and send get back to me with the required information privately also.
Thank you!
Gregory
passiveegg
I tried that and it worked, nothing happened to my account actually. I talked to a mod and they said it should be fine.
@passiveegg wrote:
I would suggest to make a new self serve account if you are not able to log in to your current one. This would be alot easier for you, and it would be a great idea to just save password as well when you first log in with your new account.
Making a new account would require a new SIM and different email address than the current one. Plus, transferring your phone number and credits to a different PM account is tricky.
passiveegg
Acekiller
It's a known bug so no need to get too worry.  A mod will square you up soon.
neatooo
Please contact the mods. Please include sim#, phone#, email used during activation, and detailed description of what happened.
Sending a message to the mod teams:
Contacting mods (details):
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
How to send a private message:
http://productioncommunity.publicmobile.ca/t5/Getting-Started/Private-Messages-viewing-and-creating/...
