iPhone X
04-06-2022 10:22 PM
I have a family member just switch providers to Public. Turns out the SIM card works but the new phone doesn’t add the data from plan. Does anyone know if there’s a solution to how we can use the IPhone X?
Phones
04-06-2022 11:34 PM
An iPhone X should have no issue with the data working properly, hopefully the suggested steps rectified your problem.
04-06-2022 10:37 PM
You can try rebooting the phone by powering off the phone then power back on again.
04-06-2022 10:26 PM - edited 04-06-2022 10:28 PM
@Saltyfigs , try doing a network reset and see if the phone will auto populate the correct APN settings. Here is the help article if you have to do things manually.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-iphone
04-06-2022 10:26 PM
@Saltyfigs what you meant by " new phone doesn’t add the data from plan. " ?
you meant Mobile Data does not work on the new iPhone ? If so, what iOS version is that?
First update to the latest iOS, also , make sure you update the latest Carrier Profile
