06-06-2024 07:47 PM
I have an iPhone SE (1st Gen, 2016), the reception in my office is not good. Yes, I know, bricks and concrete and all that, however, my other colleagues on other networks (Rogers etc) have reception that is just fine.
Could it be Public's network? Could it be my phone?
I have already tried the following
06-06-2024 10:46 PM
@GT99 - Maybe they are on 3G fallback? Usually 1 bar of 5G / LTE is 4 - 2 bars of 3G.
I have been going to a building that even going to the window where the cell tower is in line of sight it is still 1 bar, but when I leave it jumps up to 3-4 bars of 5G+.
06-06-2024 10:05 PM
Thanks - the iOS and Carrier Profile are up to date.
06-06-2024 10:04 PM
Thanks I will try that
The phone is set to 4G/LTE
06-06-2024 09:00 PM
Test to see if it is your phone by putting your SIM in your coworker’s phone and check the reception.
If it is good then it probably is your phone.
If it is the same, contact a CS_Agent to investigate the issue.
BTW, it the phone set on 3G or 4G/LTE?
06-06-2024 08:32 PM - edited 06-06-2024 08:34 PM
Hey @GT99, do you have any colleagues/friends on the TELUS/Koodo network at the office to compare with? How is your reception in other areas outside of the office?
I was on Rogers up until last month and found my signal strength on the low side at my office but now with PM it's noticeably quicker. Not saying that it's better than Rogers but in my case I must have TELUS towers closer by than Rogers ones
06-06-2024 08:01 PM
I don’t think it’s a phone issue, I have iPhone 6 (older than iPhone SE) as a backup phone, it’s working fine in my area, it’s possible to be Public mobile coverage in your area.
06-06-2024 07:53 PM
hi @GT99
is your friend with better reception with Rogers using the same phone?
your phone is a bit old, so, it is normal that it might not work as well
But if your best reception is mainly about voice calls, dropped calls, then it is a widespread issue here lately. not sure what happened, but we think Public Mobile is on it and hopefully get that resolved soon
and you update your iOS? and you updated Carrier Profile?
