iPhone 7
Electro_Mac
Have a older neighbor he has an IPhone 7
Does anyone know if the phone will work using a SIM card?
Like to get him switched over he’s paying almost a 100/month through Bell.
@Meow wrote:
I see no reason why iphone 7 would not work with PM.
If you are PM customer take your PM SIM and plug it in into his phone. Use adapter if needed. That will be sure bet test.
There isn't any possibility of an adapter being needed. The iPhone 7 model uses nano SIM.
DennyCrane
iPhone 7 will work, yes. However it won't work for phone calls in the US because it's not on Public Mobile's VoLTE whitelist. And eventually in Canada they'll have the same issue (once Canada turns off their 3G networks), but that's probably not for a couple years yet.
Electro_Mac
That’s a great idea…I’ll give it a try…Thank you!
TheSterlinger
There should not be any service interruptions.
Meow
