11-23-2022 07:45 PM
I recently signed up for 4 G but my phone says 3G. Can I assume settings need to be changed?
How to??
Thanks
Service
11-23-2022 08:22 PM
@NiagaraPete As mentioned above, make sure LTE is selected in your Cellular settings. Try rebooting your phone and/or enable/disable airplane mode. If all this don't help, you might have to reset network settings. In this case, all remembered WiFi networks will be removed. Also, sometimes iPhones need carrier update so check for that too somewhere in settings.
11-23-2022 08:15 PM
Thanks for the help. I’ll check when I’m using mobile again. It setting me though when I’m using data it says 3G but I’ll verify.
Thanks
11-23-2022 08:03 PM
HI @NiagaraPete
first, make sure you are not checking the signal when you are on a voice call. PM uses 3G for voice and so you will see it on 3G when you are in a call
Also, check your network type is set to 4G or Automatic.
11-23-2022 07:48 PM - edited 11-23-2022 07:52 PM
In the settings...you can select 4G (LTE), if it isn't already.
added...
Settings...Cellular....Cellular Data Options...Voice & Data...LTE
